MS Office report table format
Hi all.
I'm learning to use the MS Office Report Express VI to create Excel reports from previously customized templates on Excel. But I find that it doesn't respect table border formats. Attached you can see and example.
Francisco
(3,003 Views)
Hi Francisco,
     If you are using an Excel Template, I would suggest working with the Report Generation Toolkit VIs instead of using the Express VI. However, you may try using the "Excel Set Format" VI to customize the table borders after writing data into the worksheet if you prefer.
Hope this helps,
David Oña
(2,977 Views)
