MS WORD TABLE commands such as "AutoFit to contents" can be achieved in LabVIEW report generation?
LV 7.1 and Report Generation Toolkit 1.1.
I generate a report by the tookit.But tables are in disorder because of the different contents in cells.
Is there a way(or any function) in LabVIEW to made it like "AutoFit to contents" or "AutoFit to window" in WORD.
Windows XP SP2+LabVIEW 7.1
(3,140 Views)
try this:
From "Data" output of "Generate Report Get Data to Modify.vi"
select "Word.Tables"
connect it to an Invoke node and choose "AutoFitBehaviour"
Regards
CLD - Labview Certified Developer
(3,135 Views)
Where is this VI that you say to take the "Data" output from located?  I can not find it on the Palette.
I need to do the same thing to a word report I am creating, autofit the tables to contents (except certain ones) and need to know how to access that property.
EDIT - Nevermind - I found it.
Ryan
Message Edited by RVallieu on 04-26-2006 04:14 PM
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(3,109 Views)
