MS office report function does not work after building the appication
I use the MS office report function  with a custom excel template my application.
It works properly in de developstate, but after building the application it does not work .
I use office 2000  and Windows XP
(2,983 Views)
When you build your exe, in the "Source Files" tab, click "Add Dynamic Vi..." and add the "_Word Dynamic.VIs. from the "vi.lib/addons/_office/_wordsub.llb"
Good Luck,
Mike
(2,965 Views)
What error message if any did you get? It could be a couple things:
1. Did you include the Report Toolkit's dynamic vis in the app's build process?
Ref: Error 7 when Running an .EXE Using VIs from Report Generation Toolkit for MS Office
2. How are you giving the path to you custom template, as a relative or an absolute path? The path will be different for the .exe. You have to strip twice.
Ref: Why Can't My Executable Load My Included File When I Use Relative Path Encoding?
Fading out. " ... J. Arthur Rank on gong."
(2,962 Views)
Thank you Mike and Donald. The problem has been  solved with your help
(2,950 Views)
