MSI problem when trying to install LabView 6i
I'm trying to install LabView 6i on a W98SE system. The install has worked previously, but for some reason is now failing. I get the following error message from the Microsoft Installer:
The feature you are trying to use is on a CD-ROM or other removable disk that is not available.
Insert the " disk and click OK.
Seems simple enough, except for the proper disk is already in the CD-ROM. I'm assuming its looking for the .msi file, but when I point to it (lv60.msi) I get another error:
The installation source for this product is not available. Verify that the source exists and that you can access it.
Anyone know what'
s wrong? Its a little frustrating, especially since several successful installs have already been done.
Michael J Eggertson
Department of Chemistry
University of Washington
mje1@u.washington.edu
(3,026 Views)
I got this error when trying to upgrade to DAQ 6.9 when using the Student
Version of LabView 6i. Note that the Student Version of LabView does not
support DAQ upgrades, I found this out the hard way. By the way, I'm a
fellow UW student, in the Physics Dept.
I had to remove all instances of LabView and DAQ to reinstall.
Jeff
"M. J. Eggertson" wrote in message
news:506500000008000000F6200000-991728092000@quiq.com...
k OK.
> Anyone know what's wrong? Its a little frustrating, especially since
> Michael J Eggertson
(3,026 Views)
Did you try copying the files into your HDD and installing it from there?
Funny thing is that I received the same error message while installing MS Office 2000. I couldn't find a solution to it and so the old "reinstall" Windows trick worked. It solved the problem.
Shan Pin Koh
(3,026 Views)
