MSXML2.IXMLDOMNode
I'm using MSXML version 3. I'm  trying to create a Node but something is wrong. I get the error 97 (see the picture below)
I tried the LabXML-Code but i get the same error.
Anyone have an idea?
Achiles
Gnaoui Bouchachiya
(4,008 Views)
hi there
you have to open a reference to the node object. place a "Automation open" function INSIDE the for loop, open a reference to the DOMNode object, and close that reference INSIDE the for loop. after that close the reference to the XML obeject OUTSIDE the for loop.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,002 Views)
Now i get  another Error (3005)
Gnaoui Bouchachiya
(4,000 Views)
hi there
there's an error "(Hex 0x80070057) Invalid argument (src/dst cannot be the same or blank; product must be blank or a valid entry)" after the CreateNode invoke node. thus the resulting Node reference is NULL.
use all error clusters as pass through parameters to avoid error leakage.
Best regards
chris
(3,994 Views)
I don't know. It does not function Smiley Sad
Gnaoui Bouchachiya
(3,986 Views)
