MT DQPSK (pi over 4) Transceiver.vi example, where to wire base-band digital I and Q for a RTL-SDR
I am trying to use the MT DQPSK (pi over 4) Transceiver.vi example to demodulate base-band digital I and Q from a RTL-SDR.  Where in the example should I wire in the baseband I and Q?
(3,331 Views)
You will need to go down 2 levels of sub vi's. First go to niDMT.lvlib:mod_PSK Transmitter.vi. Then down to niDMT.lvlib:mod_Create TX Sequence.vi. Then change the polymorphic vi niDMT.lvlib:MT Generate Bits to user defined.
Carl W.
Applications Engineering
(3,245 Views)
hello ,
I am working on MT DQPSK (pi over 4) Transceiver.vi block diagram.I am trying find a input but I cant find.I am wondering, at this system inside input value , is it   ''seed in'' ? I am not sure because I am a internship student if you can help me I am be happy.
Thank you
(3,097 Views)
Hello Gizem,
I was trying to find the example that you mention and I got to the following page:
“Modulation Toolkit Shipping Examples”
http://www.ni.com/white-paper/6722/en/#top
I opened the examples from the “Demodulate FM (Simulated Data)”:
https://forums.ni.com/t5/Example-Code/Modulation-Toolkit-Demodulate-Frequency-Modulation-FM-with/ta-...
But I wasn’t able to find specificaly the DQPSK (pi over 4) Transceiver.vi that you mentioned. Could you please indicate me where do I find that VI so that I could assist you?
Daniel.
(3,056 Views)
