MT modulation toolkit problem : Am modulation demodulation
please i am facing few problems in labview.
1- i did an Am modulation application using labview. for demodulation i used "MT modulation toolkit" but  i faced a problem while wiring the desired signal  to the demodulation block saying "you have connected two terminals of diiferent types" but i am not able to solving this issue.
2- the second problem was in using a lowpass filter which always show up the following error whatever are the inside parameters "Error -20023 occurred at Filter->Amplitude Modulation (AM)-demod.vi "
i would be thankful if someone can help me.
thank you in advance.
Message 1 of 1
(2,691 Views)
