MY LVOOP solution to CLD- Security System
This is Siva... Now i am practiseing examples for CLD exams.  your attached prectise code was too good. I got new experiance with LVlOOP.
I have one clarification can you please Help me.?
You build the logic as a array concept. Its good. But, In NI security system Model question paper.  They have mention the 6 zones(alarm switches , Bypass Switches and Tamper Switches) as a group of cluster.they formed the group of switches in one cluster. you formed the Zone switch as a single cluster.
Whether they will accept these type of control changes?
Message 11 of 14
(883 Views)
I think that would be ok.....You can do that if your complete code is getting modular.....
I am not very sure, maybe some NI person can help us here.....
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 12 of 14
(881 Views)
Hi Thanks for your kind replay.
I have one more clarification. What is the advantage of using Object control Instead of cluster? this is the first time, I am seeing this object control.
SIVA
Message 13 of 14
(859 Views)
With LVOOP, I save on the time required to create a template which accepts cluster input, error input and give respective outputs. Also, I get different ready templates for Read/Write Data access, Dynamic Dispatch etc. in LVOOP, thus saving me time to create templates.
You can use clusters here. However, I am comfortable with LVOOP since I use it for large projects for Object Oriented Design.
I have given my CLD with LVOOP, am waiting for the result. However, in my CLD, I used LVOOP as well as clusters for different purposes.
-FraggerFox!
Message 14 of 14
(852 Views)
