[Mac] Building DLL with LV6
Did someone successfully built a DLL using LV6 on a mac.
I get -1728 error (AppleEvent Error, missing param) in the last step of the
built process right after the "building application..."
If the answer is yes, please let me know.
Thanks in advance
Chris
Christophe Salzmann tel. (+41) (21) 693.38.49
Institut d'Automatique - EPFL fax. (+41) (21) 693.25.74
Swiss Federal Institute of Technology
Switzerland
mailto:christophe.salzmann@epfl.ch
http://iawww.epfl.ch
(3,473 Views)
I tried also to build a Shared Library (DLL) on LabVIEW 6 on Mac OS. I got the same error. I just came across what I believe is the answer. You must have Apple MPW (Macintosh Programmer's Workshop) installed on your computer. I have not tried this yet, but I believe that it is the problem. It makes sense, however, that LabVIEW uses some functionality of MPW and uses AppleEvents to do so.
(3,472 Views)
Hello Christophe
I have a problem with one very old Mac computer (MX II) which is not working anymore as it should be, so I want to migrate my  old .VI´s files version Labview 2.1 to a newer version of LabView (8.2) but for a PC and I haven´t succed until now.
I want you to ask for help because I have already some moths trying and now i don´t get any new Ideas how to do it.
If it is possible please let me know that to my mail so I can send you my files,
my mail is
Thank you!!
(3,311 Views)
Greetings!
    The following link is a great starting point for trying the upgrade. Mac OSX opens VIs that are built in windows and vice versa.
http://forums.ni.com/ni/board/message?board.id=170&message.id=164623&requireLogin=False
http://digital.ni.com/public.nsf/websearch/AEA66B26C66775B6862571FB006E29AF?OpenDocument
http://digital.ni.com/public.nsf/websearch/429E45271CFD683786256D87006B1EEF?OpenDocument
http://digital.ni.com/public.nsf/websearch/5197A72B2D60C141862570DC004CB534?OpenDocument
It is a huge shift and you might come across some issues of older VIs no longer in the pallette and so forth.  So lets try one step at a time. Please let me know how it goes.
Thanks and hope this helps. Good luck
Best regards
Avi Harjani
(3,293 Views)
