Mac G4 crashes using continuous generation with PCI-1200 DAQ card
I've been trying to use a PCI-1200 DAQ card with a Mac G4 to create a continuous analog output signal. The problem is that the computer locks up after a while (a few minutes). I have been using the Generate Continuous Sine Wave vi, but the problem remains.
I've tried slow signals (10Hz) and fast signals (2kHz) but the computer still seems to crash. I have no clue what is going on!
(2,439 Views)
bissdp,
The first thing I would recommend is making sure you have the latest version of the driver:
www.ni.com > Support > Drivers and Updates > Current Versions > Multifunction DAQ
Another you could try is to determine what component is causing the computer to lock up. Use a process explorer utility to try to see what processes are locked up. A search in google might turn up utilities like this one: (http://www.clarkwoodsoftware.com/peekaboo/)
Keep in mind heat or speed issues. It may sound funny, but you may want to try opening the computer case and making sure the board has enough air flow to keep it cool.
These are just some ideas for now, I hope they help.
Alejandro Asenjo
(2,439 Views)
