MacOs: HowTo remove com.ni.ServiceLocator??
I have tried one Labview version on my Mac some time ago and removed it,
today i found the the console if full with the following messages:
23.04.09 07:27:05 com.apple.launchd[1] (com.ni.ServiceLocator[7182]) Exited with exit code: 1
23.04.09 07:27:05 com.apple.launchd[1] (com.ni.ServiceLocator) Throttling respawn: Will start in 10 seconds
23.04.09 07:27:15 com.apple.launchd[1] (com.ni.ServiceLocator[7183]) posix_spawnp("/Library/Application Support/National Instruments/Service Locator/nisvcloc", ...): No such file or directory
it seems to me that there are some relicts of the Labview installation, how can I remove the script that triggers the launchd daemon?
best regards
(5,303 Views)
Hey,
i hope you installed the MacOS LabVIEW version.
I found a KB to disable the Service Locater: http://digital.ni.com/public.nsf/allkb/FB8F357CEADE7DF186256CCA00191C6D?OpenDocument
Kind regards,
Elmar
(5,270 Views)
Ys it was the OSX version,
i know the KB-entry, but i removed LV already,
so the paths and files are not there anymore.
best regards
(5,266 Views)
Accepted by topic author N.Schnitzler
Ok,
there must be a old data entry that produce the message.
Please take a look on your drive /Library/LaunchDaemons und /Library/LaunchAgents and delete the file manually.
Kind regards,
Elmar
(5,234 Views)
your hint workes.
thank you
best regards
(5,216 Views)
