Macintosh Aliases
Does anyone know how to distinguish between an Alias and the actual
file/directory? I am trying to list out the entire contents of some
directories, and also determine the total directory size, but whenever
the directory contains an Alias to another folder, Labview keeps going,
listing the contents of that folder as well (if it finishes) as if that
folder were an actual subdirectory. I am using Labview 5.1.1 (on a Mac
Paul Davey
Research Assistant
School of Physiotherapy, Curtin University of Technology
Selby Street, Shenton Park, Western Australia, Australia. 6008
email: P.C.Davey@curtin.edu.au
Tel. +61 8 9266 4657 Fax. +61 8 9266 3699
"Everyone who calls on the name of the Lord will be saved." Roma
ns 10:12
"For all have sinned and fall short of the glory of God, and are
justified freely by his grace through the redemption that came by Christ
Jesus." Romans 3:23-4
(2,614 Views)
I've never used labView on the mac, but I have played around with them. One thing that springs to mind is
trying the "File Type and Creator" vi on directories. You might find that aliases have a different file type
to true directories (although that vi might fail on both).
I hate to guess what happens under OSX!
I have a related problem under Windows 😞
I want file information for everything in a directory tree including following shortcuts (aliases to you).
The "File/Directory Info" vi fails with a "File not found" error if the path to a given file includes a
shortcut!
(2,614 Views)
