Main VI not visible
Is it possible to configure a main as not visible?
I have a main VI that calls some dialog box but it is not very beautiful with the main VI always visible.
I tried to configure in the VI properties the VI appearance: "show front panel when called" But it does not work.
Maybe it 's possible to run it in background ?
Thank you
labview 7.0
(3,991 Views)
If I have this problem, I will Add [Hidden] to Properties [FP.State]
LabVIEW 7.1
(3,983 Views)
If I understand well, you want to hide the front panel during the execution of your vi.
I build an example using the property node FP.State which allow to do this.
I hope this example answers your question.
Benjamin M
NIF
(3,952 Views)
Thank you for your Vi but I can't open it , I only have Labview 7 express....
I tried to configure in properties but It seams that the VI is not not launched in background
labview 7.0
(3,932 Views)
here is the same vi saved in LabVIEW 7.0.
Benjamin M
(3,929 Views)
Thank you very much it works perfectly.!!! Smiley Wink
labview 7.0
(3,925 Views)
