Maintaining *.lvlib inside another *.lvlibs
Good day!
I am new to LabVIEW, I use version 2018. I want to have library that contain some sublibraries. On disk it looks like this:
Custom Libraries folder
    - Library 1 folder
          - Public folder
          - Private folder
          - Library 1.lvlib
    - Library 2 folder
          - Public folder
          - Private folder
          - Library 2.lvlib
When I add Library 2 to Library 1 via project manager and save Library 1 it shows me that Library 2 change its membership, and if I try to open Library 2 separately it opens Library 1 that contains Library 2. Why this happens? In text programming languages if I have Library 1 that contain another Library 2 I can use Library 2 separately and don't load Library 1 to project to use Library 2. I figure out if I copy Library 2 folder to Library 1 folder and add it to Library 1 via manager then I will be able to use Library 2 separately if I use it from its own folder. With this situation I have question: how can I maintain Library 2 if it will be used in many others Libraries? I will have to copy Library 2 manually to all Libraries that use it?
(2,574 Views)
Sounds like Library 2 does not actually belong inside of Library 1.  But that does not mean you cannot call VIs from Library 2 inside of VIs in Library 1.
(2,544 Views)
After a little bit of time, I think I should have put a little more explanation in.
I'm lazy, so for now on I will use X for Library 1 and Y for Library 2.
When you add Y to X, you have now made Y part of X. So if you load up Y, it needs to load up the context (X) it is part of. Based on the rest of your description, you have actually created a reverse dependency. We don't want that. But any VI, whether or not it is in a library, can call any public VI in Y. So you just have X.lvlib::a.vi call Y.lvlib::b.vi and your dependencies are in the correct direction (X will depend on Y, Y will not depend on X). Y can live in isolation and be used by anybody.
(2,537 Views)
