Make 3D picture control object transparent?
Hi all,
I did the following:
* create a 3D scene with a rather flat box (like a sheet of paper)
* put a texture on the box; the texture comes from a png file and has transparency
I can now see the objects ambient color through the transparent texture. Ok.
I now tried to make the object itself (its ambient color) transparent, in order to have the texture bitmap as a free standing 3D object, like cut out from a piece of paper. Using the alpha channel does not work - the object remains opaque all the time.
Any ideas or hints out there?
Best regards
Matthias
(4,997 Views)
You probably are applying the texture as a decal instead of as a replacement.  See the "Apply Mode" property on SceneTexture for more details and/or check out this example.
(4,968 Views)
You probably don't need it, but on the VI that I posted I forgot to add indicies to the second mesh.  Here is an updated VI.
(4,959 Views)
thanks a lot. That was an excellent solution; I also appreciate the idea to put the texture onto a simple quad mesh instead of putting it on a box, as I did. My box always had a backside (I could get rid of the other 4 faces by making it very thin), and that shone through to the front side after the transparency thing finally worked... So: Great!
Regards
Matthias.
(4,951 Views)
Ok a big piece of thread necro here:
I am trying to generate a texture for placing on an onject with alpha transparency and I am having trouble formatting the data correctly so that I can apply it.  I have tried modifying the blending.vi but to no avail, I am doing something wrong converting from a (present) 8-bit texture to a 32-bit RGBA texture.  Anyone know how the pixels are arranged internally in a 32-bit texture?
Shane.
ps I think I may have misudnerstood the importance of the mask data.  I assumed since the data was 32-bit that the transparency was in there, but perhaps this isn't the case?
(4,066 Views)
I got a little stuck on this as well. Turns out that the flattenned pixmap can also be 32-bit!  (24-bit RGB + 8-bit Alpha) You'll have to roll your own conversion, because the C:\Program Files\National Instruments\LabVIEW 2018\vi.lib\picture\pixmap.llb\Flatten Pixmap.vi doesn't have this capability.  You can get a example of a 32-bit pixmap by following the Read PNG file.
http://zone.ni.com/reference/en-XX/help/371361N-01/lvpict/read_png_file/
as Intaris pointed out elsewhere, 255 is opaque and 0 is transparent.
(2,873 Views)
