Make Camera and PPT Talk
       Now I have two vis.One is for controlling the changing rate of slide. Another is for capturing image through camera. Here is function  I want to achieve. When the slide change, it will talk to the camera  and make it take images. The rate of the slide.My problem right now is the "Talk".
(2,758 Views)
Hi Aliasff, the VI you attached is not opening since some VIs are missing.
Can you elaborate a bit more on the VI objective, the issue and how you are trying to achieve it, please.
Eric_NI
AE
(2,730 Views)
