Make Current Values Default in running subVi
The easiest way to have a setup file in your local drive and a configure subVI in your program.
The configure VI would read from your setup file and will have the facility to modify the setup file. You can use CONFIG VIs for this purpose. If you need more information, let me know and I will put an example here.
Kudos are the best way to say thanks 🙂
Message 11 of 11
(485 Views)
