Make One Stop Button on Two Programs VI
Hi all.
I'm making a simulation program on two FPGA LabVIEW. I use Desktop Execution Node on the host to unite the two FPGAs. I use the first FPGA as a signal generator that sends signals to FPGA 2, and the second FPGA I use as a series of executors. I run the program on Host and set the running conditions of the program on FPGA 2. But, if I Stop FPGA 2, the circuit will be error because it must be stopped via Host.
I want to ask, how do I unite Stop Button on FPGA 2 with Host? So that when the Stop Button on the FPGA 2 is pressed, it will stop the program as it should when the Stop Button on the Host is pressed.
thanks.
(2,992 Views)
Accepted by topic author fathurrkoesn
How do you normally/want to stop the program(s)?
It sounds like your normal Host.vi (which I guess is not the one in the screenshot - that's the test VI?) would normally pass some signal to FPGA(1), which would then communicate this to FPGA2, which would then stop.
In that case, just do the same - communicate the Stop signal (message, tag, whatever) to FPGA(1), and then let the simulation propagate that to FPGA2.
You can use some other method to stop the While loop in your simulation VI - either a Delay node with a specific delay if you know approximately the number of iterations to stop, or perhaps the error wire from the DENs?
I'm not sure what you mean with this bit:
[I] set the running conditions of the program on FPGA 2
so perhaps I'm misunderstanding the post... do you mean you change the behaviour during DEN simulation by altering FP values on FPGA2's main VI? If so, how do you normally (i.e. not in simulation) adjust these values? You could also do that in simulation (if it isn't overly complicated signal patterns that you've already tested work properly).
(2,944 Views)
Thank you for your reply, cbutcher!
(2,889 Views)
