Make Smaller Icons
Little something I learned today that is pretty common knowledge I'm assuming, but I didn't know about it and have been working with LabVIEW for a couple of years now. Therefore, I assumed some others wouldn't know about it either. While there are wiki's out there that explain this, I know I usually come to these forums before googling so I thought I'd put something here.
In a recent project had a very simple action engine that appends update strings in multiple different threads, based on what has happened within the program, and displays them to a user in another thread that is there specifically for front panel updates. However, this action engine was way too clunky and took up too much space on my block diagram for something only having two input terminals, and 1 output terminal. Doing the following cleaned stuff up incredibly, especially in case structures where the only reason they were taking up extra bd space was because of this action engine...
 First, show your connector panes and make sure your have the bold area around the terminals you want to use. Then make sure you have each of the icons circled in red looking the same (you can do this by selecting one then copying it and pasting it into the other two boxes)
after that, voila, add it to your bd.
If anyone else has any other tip/tricks for icon editing feel free to add them.
Message Edited by for(imstuck) on 02-12-2010 01:44 PM
Message 1 of 13
(14,873 Views)
Nice!
But....
You stoped one step short or nirvana. Smiley Surprised
*Create a warpper for each of the two actions (include the enum in the wrapper) and edit those icons similarly. Using a warpper for each action gives you
1)the ability to mark the input terminal on the "write" wrapper as required while also
2) loosing the  enum on top. This also,
3)  minimizes you (well maybe not you but me anyway) forgetting to set the right action.
Ben
* Idea of wrapper for each action was given to me by Jim Kring. It is a gift I use regularly.
Message 2 of 13
(14,846 Views)
Making smaller icons is described in the LabVIEW help (icons>custom-shaped) and there is an example called Custom Shaped Icon (strangely enough).
Message 3 of 13
(14,825 Views)
Within the last week I've actually posted TWO examples where I use small icons for sub-vis
CCI Time to Excel
and Magicically dragable Coersion Dot
For Style though- "A meaningful Icon should be created for all subvi's"  the real estate on the BD is useful for aiding the user and the developer trying to debug.  Be careful with WHEN you chose to reduce your ICON size lest you obfuscate the code (Hmmm LV Proverb?)
"Keep Thine Icon size maxim unless less is more"
Message 4 of 13
(14,818 Views)
This was a good topic to mention.  It is one of those things that people might not think of.
One tip (and I think you basically said this, but not so clearly) is to make sure the X of the connectors you want to use are within the boundary of the icon you are creating.  In your case where you use one of the top connectors, the X is slightly below your rectangle, thus you see a bit of the wire passing through your icon and hitting the X that is now below your visible icon.  To correct this, you may want to pick a different connector pattern such as the 4-1-0-4 rotated 90 degrees.
It has 4 connectors across the top that have small enough squares so that all their X connection points would fall within your icon.
Message Edited by Ravens Fan on 02-12-2010 03:52 PM
Message 5 of 13
(14,813 Views)
Agreed. I should have mentioned this as random whitespace can look a little funny Smiley Sad. Also, to comment on your first sentence. That is why I posted it, because often there are things that might seem common, but people don't know about/ think to look into further. LabVIEW is a big package and finding all the little things that may help can often be overwhelming. That kind of goes along with the post from Dennis. Yes, there is something about it in the LabVIEW help. But as we have seen on these forums, often people don't bother to look 🙂 (as I didn't bother to for a while). Therefore, I hope this post can just make people aware that this is an option thats available. Maybe next time they will think, hey I could use that idea I saw on NI's forums.
Message 6 of 13
(14,801 Views)
Ben wrote:
Nice!
But....
Ben
I've been doing this for years, and there's even one more step to nirvana:
Create a polymorphic of all the wrappers.  That way you simply lay down the poly and it will automatically adapt to get/set functionality based on how you wire it.
For more complex AEs (with multiple actions), I still like to create a polymorphic of the wrappers, but I additionally choose to show the polymorphic instance label.  Now you have a single, easily usable interface to your AE.  All I do is plop down the poly, and select the instance I want on the block diagram.  With the label, anyone reading the code can easily understand what's going on.
Message 7 of 13
(14,705 Views)
The small Icon idea also works wonderfully for large Cluster constants.  Simply put the cluster constant on the BD and add an indicator.  Create a small icon and now you have a Small but usefull cluster constant when Bundling data together 🙂
Craig
LabVIEW 2012
Message 8 of 13
(14,177 Views)
CCI Time to Excel
Oh that reminds me of some odd code.  I once saw a sub VI that had one input one output, and the icon looked like an array of string wire.  So when you wired it up to an array of string in, and array of string out, it looked like there was no sub VI at all.  The code was not written by me, or anyone I know, but secretly manipulating data makes debugging software very difficult.  In your case I'm okay with it because you can see data changing, but my example is just another reason why code review is not a valid method of unit testing.
Message 9 of 13
(12,944 Views)
People will always find a way to abuse the system Smiley Sad. As with all things, common sense should be applied. In my opinion, that developer used none. I am actually in favor of only using the standard sized icons for the most part. However, if I have some sort of error handler that only takes an error input to publish or something, I will make a small rectangle icon with only error in and error out so my queue ref wires don't have to navigate it etc. The more you develop, the more you learn to organize your VIs on the block diagram in a way that you can avoid bent wires even when using the standard icon size. But for certain cases, it is certainly nice to be able to reduce the size.
Message 10 of 13
(12,925 Views)
