Make a Call from PC with Labview
Sorry but your question does not make any sense.
Message 11 of 13
(782 Views)
ok.....y want to make a phone call from mi pc trough modem port (rj11-com3), I think so I need to use VISA SERIAL to use that COM, but i don´t now how to listen when I pick up, because the VISA READ send me string....
thank you!!!
Message 12 of 13
(769 Views)
When you make a call out you use AT commands and you don't listen for any sort of sound. You write and read responses from the modem. The responses (read with a VISA Read), will tell you whether the modem has successfully gone off hook, dialed, etc. The AT command set is published in numerous locations. I would suggest you search for that to get a deeper understanding.
Message 13 of 13
(762 Views)
