Make a bode diagram of the signal gained from the pxi 5122
I have a question.
I would like to make a bode diagram of a signal from the PXI 5122 scope. The only vi's i can find are with zero-pole-gain models, and i dont have a zero-pole-gain model. i just have a signal from the 5122 and i want to peform a bode diagram.
any suggestions?
Thanks in advance.
Henry Lootens.
looyenss@gmail.com
(2,433 Views)
Use a Graph, x axis Frequency, y axis Magnitude, set the x scale mapping to Logarithmic.  Bundle the two arrays of data as frequency then magnitude before connecting to the Graph.
(2,411 Views)
