Make a label with not transparent background
When generating a label control, the default background color is transparent, but once add a color for it, it will show a raised box. How to make a  label with background color and has the flat format?
David
(4,612 Views)
My guess is that youre setting both boxes on the colour picker
Set only the bottom box, and have the top colour picker box transparent. This way the frame giving the raised effect remains transparent i.e. unseen.....
(4,603 Views)
Once you have the color picker, select the desired color, then hit the space-bar to only select the outline color and then select the transparent color in the upper right.
Hitting the space-bar toggles between the different combinations of elements to be colored, just play around and you'll get the desired effect.
Message Edited by altenbach on 07-15-2006 07:41 AM
(4,602 Views)
