Hi!
I have done that, but i have the same problem.
I want to control an application from a remote machine. At the biguinning of the application, I have so open a File to save all the data to this file. When I run the application from the server machine, I have no problem, the dialog box "save as" opens and I save there my file with al the data, but when I control the application remotely, the dialog box "save as" does not open, and I get the error 43. Do you know what do I have to do if I want to run and control the aplication from a remote machine and save all the data in a file?
Thanks a lot
