Make a six sided Dice
how do you make a 6 sided dice subvi using boolean indicators?
(3,844 Views)
Why do you keep creating a new thread for the same subject? You have already been given a lot of your project. Also, your question here does not make much sense.
(3,839 Views)
okay on the front panel how would you put leds in a square in order to have them act as a die to where if you rolled say you roll a one the center light will come on but no other are visible
(3,827 Views)
Use a 3x3 boolean array of LEDs. Create the right pattern for each value using a lookup table.
(3,823 Views)
Here's what I had in mind ...
(3,809 Views)
