Make current values defalut while a vi is running in LabView.
So, is it possible to make the current values of a vi's controls default while running the vi? I have a pretty sophisticated vi, with custom menus and all, and I'm trying to set it up so it can remember which channels to use, since it varies from instrument to instrument. I wanted to just store this info in the default values of the controls, but LabView doesn't seem to like it. I was trying to avoid any config files, so is there a way to make the current values of a control default while the vi is running?
Mike
mje1@u.washington.edu
(2,716 Views)
Here is link to one example
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&2C14132F826F839F8625683A000B0B99&cat=DB5863CD70417B07862567930070A058
Attached is another version of doing same thing. Hope this helps.
A Rafiq
http://www.ni.com/ask
(2,716 Views)
Thanks, I managed a similar workaround by storing the flatened data in an ini file.
Mike
(2,716 Views)
One more time, make values default only works in DEVELOPMENT enviroment, VI server property won't work if you make an executable (*.exe) file. The reason is you can't edit a diagramless vi. If you are not going to make an executable from your vi, you can use this vi server capability.
Hope this helps
(2,716 Views)
