Make graph line transparent programmatically
I would like to be able to make graph lines transparent from within LabVIEW.  Is this possible?  I can find property nodes for every other property, but I can't see the one which turns on the Transparent bit.  Any suggestions?
Ian
(3,027 Views)
Accepted by topic author IanDeaville(ZF)
Hi Ian,
By "graph lines" I assume you mean the plotted data? If so, then you could use the property node for "plot color", change it to write and then wire a color box constant set to transparent (T) to it.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(3,024 Views)
Thanks very much for that.  I hadn't realised that this was an option - far too easy.
Ian
(3,013 Views)
