Make image appear for certain value
Hopefully this will be a simple solution, but I don't have much experience with extracting images into labview:
My program uses a DAQ to measure the energy produced by someone on an exercise bike apparatus. I have a calorie indicator for this, but would now like to make things a little more visual... For every 280 calories that are produced, I would like LV to output an image of a pizza slice, and to output one for each multiple of 280, but rotated at an angle to create an entire pizza. For instance, once the 280 cal is reached - image appears. When 560 cal is reached, an additional image appears, but rotated at 30 degrees (or however thin the pizza slice is...). When a full pizza is made, I'd like it to start "building" another one.
How would I go about doing something like this?
Thanks for your help in advance 🙂 Let me know if you have any questions.
Message 1 of 8
(4,654 Views)
Hi dancintoothbrush,
You can use a "Pict Ring" for this task.  I have included a sample VI that demonstrates what I mean.  Basically, I created nine different jpeg images.  Each image contains 0..8 slices of pizza.  I then imported each image into my picture ring.  As the VI runs and the calories increase, the picture ring index increments.  Thus, at 0 calories, picture ring index number 1 displays.  At 560 calories, index number 2, and so on...  When the index number reaches 10, the process repeats.  Does this solution work for you?
Message 2 of 8
(4,637 Views)
Hi Peter,
Oh my goodness! It's beautiful! And you did all the work for me! 😄
Thank you so much!! *life saver*
~Nadia
Message 3 of 8
(4,610 Views)
How about displaying and arranging individual beers to make six packsvery-happy smiley.
Cool project, by the way. Good Luck!
-AK2DM
Message 4 of 8
(4,600 Views)
Haha, that would be great
...except that this project is for 8-12 year olds, to teach them about energy and power 😛
Message 5 of 8
(4,595 Views)
HI! I'm actually working on a very similar project. I want to use the same idea except add jelly beans to a jar for every 10 calories burned. How do I change the pictures from the vi that is already posted above? Any help would be appreciated!
Message 6 of 8
(4,428 Views)
Search LabVIEW help for Picture Ring.
Message 7 of 8
(4,426 Views)
thanks so much! I figured it out!
Message 8 of 8
(4,423 Views)
