Make indicator boarder less and transparent background (invisible)
Happy new year to all.
Is there an easy way to achieve the functionality in the picture below:
I want the bold zeros to be terminals on the block diagram that I can update.  Would you agree in saying the top set looks better than the bottom?
Kind Regards
Lewis
Lewis Gear CLA
LabVIEW UAV
(3,941 Views)
Accepted by topic author Lewis_G
Here you go
Start with the simple numeric the trick of course is to set both the BG and Boarder to Transparent by toggling (or left click and right-click) and select T for both
(3,935 Views)
That has done the trick, thanks.
I have not seen a simple numeric before, which palette are they on? (I can only find them on quick drop).
Lewis
Lewis Gear CLA
LabVIEW UAV
(3,920 Views)
Classic>>Numeric
(3,914 Views)
Just as an aside and to prove the universe is run by serendipity,  Guess what I needed to drop on a UI this morning.
Spoiler
Yup invizable Numeric.ctl-  customer requirement that was unexpected but I did have a solution handy.  go figure
(3,873 Views)
Thank you for the information but i need to know the steps to make a transparent indicator (where i can find the BG and Boarder).
(3,454 Views)
