Make invisible individual tabs, not all of them?
Well I get that when you setup a Tab Control, you can right click on it and under the revealed menu options is an option to make the tabs of the tab control visible or invisible (at the top of the menu). I was wondering if there is a way to make only a select number of tabs invisible, and not the whole row?
I am creating a slideshow with the tab control. I want the user to be able to click on certain tabs, but then othes will remain invisible (not clickable), but they will show up as the tabs progress through the slideshow. Hope that makes sense.
(3,035 Views)
aputman
(3,028 Views)
Thanks, aputman, that helps a lot. Can I ask, what is that node/function in the center which the Tab Control indicator is connected to? It looks like an Index Array. There are several similar ones in Labview. Guess I'll try them out.
(2,969 Views)
The output of the pages node is an array so the node in question is an index array with the page on question feeding into it then it feeds that value to a visibility node.
Doug
"My only wish is that I am capable of learning each and every day until my last breath."
(2,960 Views)
