Make "free" profiles from an array
Hi.
I have a system for measure the current of a photovoltaic plate, the current of each point is saved in anm array and showed with a gray scale image (you can save the image) now i want to make profiles from this image (array) drawing a line on the array and i dont know hoow to do it. I give you the front planel of the array.
Message 1 of 21
(2,313 Views)
Hi diego,
This is like giving a photograph of your car to the garage and ask the mechanic to repair your car…
Use a cursor of the intensity graph to let the use select the row/column of your 2D data.
Then use the cursor position to index the corresponding data from your array and to display a profile plot from these 1D data…
Message 2 of 21
(2,305 Views)
I can make profiles of a col and a row, but i dont know how i can do the same for a line that the user draw. Sorry for the image, i send now the back panel of how i do the profiles of rows and cols
Message 3 of 21
(2,298 Views)
Now there's a picture of the engine!
Message 4 of 21
(2,252 Views)
Hi diego,
as RavensFan already said: it's still a photograph of your car, you just opened the engine hood…
And it is an ugly engine! From what I see on that image is an overuse of local variables. Use more wires!
A line has two end points: you can determine their indices. And you can determine the indices of all points in between them.
After all it's simple linear algebra, usually taught in school…
(Coming to my mind: Have you ever heard of Bresenham? That's the way we calculated lines the fast way 35 years ago on 8bit computers…)
Message 5 of 21
(2,245 Views)
ok sorry, now i think we share the car.
The starter arrays come from the measures, "opciones guardado.vi is just for save the results and the first case is for work without devices.
Message 6 of 21
(2,239 Views)
Hi Diego,
We are coming closer: Now you gave us the car, but removed important parts of the engine…
All the subVIs are missing!
Is this the expected output of this code snippet?
Message 7 of 21
(2,231 Views)
Use mouse-down events to draw a line using "plot images.front".
and extract the line profile using bilinear interpolation.
(here is an old example that uses two cursors and interpolation)
Message 8 of 21
(2,222 Views)
@altenbach  ha escrito:
I try to use your vi with the interpolation and it doesnt work with other array (i think im doing something wrong), the try is in the interpolation.rar
Message 9 of 21
(2,163 Views)
@GerdW  ha escrito:
Hi Diego,
Message 10 of 21
(2,162 Views)
