Make work NI DAQ 6.8 on Labview 7.1 ?
Hello
I have a PCI 1200 acquisition card that can only work with version of NIDAQ up to 6.9.3. And I also have Labview 7.1 installed on the same PC (and a program written in Labview 7).
I would like to know if I can use the NIDAQ 6 VIs with Labview 7 ? Will it work ok ?
If yes, do I just need to copy the DAQ repertory with all the subvi on the labview 7 user.lib directory ?
Thomas
(2,714 Views)
Hi Thomas-
Yes, it is possible to use older versions of NI-DAQ with LabVIEW 7.x.  This configuration is not officially supported by either software package, but the information in this KnowledgeBase shows a method for copying all the necessary VIs over.
Hopefully this helps-
Tom W
(2,696 Views)
Thanks for all !
(2,690 Views)
