Making FPGA.vi More Dynamic
I'm wanting to make my FPGA.vi more dynamic. What I mean by that is that I am tired of having to compile every time I need to check if something is working properly. As you can see in the snippet below I am using clusters to communicate from the real time vi to the FPGA.vi.
Currently the vi takes a cluster of six outputs and there respective gains for the AO module (NI 9264):
  1. Tube_N2_MFC
  2. Pressure
  3. Tube_Air_MFC
  4. McKenna_Fuel_MFC
  5. McKenna_Air_MFC
  6. Tube_Fuel_MFC
  7. Internal Pressure
  8. Mic_Voltage
  9. Temperature_Large
and has nine inputs, six corresponding with respect to their AO/gains, two that are AI(NI 9205)/gains and one that is a TC (NI 9213) reading (conversion from TC to actual temp is done on the real-time vi).
FPGA.vi-SnippetFPGA.vi-Snippet
Say variables above 7-9 are constants. I will always only be reading from these 3 devices. However say I want to have the ability to change the pressure transducer or the microphone being used. Easy enough I add variable7_gain, variable8_gain ... values to the cluster and edit the gain values in the real-time script, boom done.
But let's say I want to be able to increase the number of AO devices from six to eight or ten or however many I desire (again with their respective gains) depending on what we are testing. Creating a bunch of different case structures would be pointless obviously because I wouldn't be able to prepare for all the different scenarios. Is there anything I can do to grow/shrink the "Switch Node" based on the number of inputs being fed through the input cluster? Or is there some obvious solution that I am missing to this problem?
I'm self-taught in LabVIEW so you will not offend me by critiquing my code. Any sort of help or tips thrown my way are always greatly appreciated!
(3,962 Views)
What cRIO are you using?  What is your loop rate?  I see a 50 in there, but is that ticks, us, or ms?  If ms, I would consider just using the Scan Engine and move all of this code to your RT.  It would be a lot simpler to update your code that way.
(3,946 Views)
Hey crossrulz, thanks for responding so quickly! I am using a cRIO-9035 and my loop rate is set to 50 us. The thing is I need to have the Output_FPGA_Cluster in an FPGA.vi because I am pulling that cluster from the cRIO to Python using the niFPGA library which uses the FPGA bitfile to read the cluster.
(3,942 Views)
1. Your code is hugely inefficient.  Using SGL when it's not needed (you can divide and multiply FXP you know - also instead of dividine, multiply by 1/x, it's far more efficient).
2. make a sub-vi with an IO Node refnum input.  Pass in a calibration value.  Make it read from the IO-Node and apply the calibration (Multiply).  You can now place N instances of this sub-VI, wire up the IO node references, pass in the calibration and you have defined a hardware function.  Do this with the other types also.
(3,906 Views)
I am understanding your first point, but I am confused on what you mean by your second one. Can you or someone else show me a small example of what you're talking about?
(3,892 Views)
You can create an I/O Node which will allow you to choose a certain port of your device via a drop-down menu,
You can define a sub-VI with such a control (See HERE) and then wire it up with a constant on the BD of your top-level VI.  this way you can re-use a single VI for multiple different channels and adding / removing channels becomes easier.
You will need one such VI for each different TYPE (not each instance) of channel.
(3,888 Views)
