Making a output text file read-only.........
Hello everyone,
I am trying to have Labview output a read-only file. But I can not seem to find a way to do it. The file that it outputs is just a text file, but I do not want the people reading the file to be able to change it. I know how to change it in DOS/Windows, but I would like it to be automaticly done by Labview.
Any suggestions??
Guess I should add that this is for use with Labview 8.0.
Sam
Message Edited by SamPond on 04-17-2007 09:54 AM
(3,234 Views)
hello,
I've one application were i done that.
See the attached pic to see how I've done it
Software developer
www.mcm-electronics.com
PORTUGAL
(3,221 Views)
I don't know if it's called the same in 8.0 but in 8.2 there is the function Set Permissions. In 7.x or older, it's called Access Rights.
(3,209 Views)
Jorge,
Thanks, That is what I wanted to do. Allready did it and works perfect.
Dennis,
Yes, there is a set of permission fuctions but that wasn't quite what I wanted to do. But thanks anyways.
(3,196 Views)
