Making a plot visible without property node?
Consider using a CONDITIONAL DISABLE symbol to control that.
If you create a new CONDITIONAL DISABLE SYMBOL called "MakeAllPlotsVisible" and enclose the initialization code in a CONDITIONAL DISABLE structure with a condition of MakeAllPlotsVisible == TRUE, then you can turn it on when you gorch the plots again, but it doesn't take up code space when not necessary.
Steve Bird
Culverson.com
LinkedIn
Message 11 of 11
(506 Views)
