Making a simple vision machine with sensor
I'm totally beginner of using Labview.
I will make a simple vision machine.
it is inspect a label on product whether it is pasted well or not
If this machine find one label, it is good and OK.
if this machine cant find label or find over 2 labels, it will be NG.
I already make a vision algorithm for detection.
but I dont know how to apply above condition for sequence.
also I want to get a image when proximity sensor is activated.
what I need to use a proximity sensor for machine
need I any board or something? what is most cost saving way for making this machine
Please tell any ideas this machine!
Or let me know usefull resourcse
Thank you
(2,763 Views)
There are numerous tutorials that will get you started learning LabVIEW -- the first page of the LabVIEW Forums contains a number of good links.  If you have any programming experience in any programming language, you should be able to pick up the rudiments of LabVIEW in a week.  If not, it may take you three weeks.
You need to put the effort into it.  Otherwise, take out an advertisement, "LabVIEW Programmer Wanted for Hire" (there's a Forum here expressly for doing this).
Bob Schor
(2,722 Views)
