Making octave plot in SVT to use g/SQRT(Hz) units
thanks a lot, I am trying to figure out how to add it to the library now.
will post updates when I get it to work... One comment: the SVT 1/3 VI's don't let me pick low frequency , 20Hz is the lowest I can go... I have to use 1/n and then I can just type the frequency and it's all good.
Looks like this attached VI does accepts the typed frequency, should work! thanks again.
Message 11 of 22
(2,827 Views)
update I just dragged from file manager into labview and the VI showed up.
I am trying to connect the output of the IEC 1/n octave analysis VI into this conversion VI and I get the following errors:
going from "octave spectra" to "octave spectrum"
You have connected an array data type to its element data type. This type conflict may be resolved by indexing the array to access individual elements of the array. Check for a tunnel on a loop that has indexing incorrectly enabled.
The type of the source is 1-D array of cluster of 2 elements.
The type of the sink is cluster of 2 elements.
and going from "octave info" to "octave info"
The type of the source is 1-D array of typedef 'svt_Octave Info.ctl'.
The type of the sink is cluster of 8 elements.
help?
Message Edited by Anatoly2 on 04-29-2005 11:42 AM
Message 12 of 22
(2,632 Views)
Here's a multi channel version of the code along with a polymorphic VI:
Chad AE
Message 13 of 22
(2,820 Views)
thanks again Chad, will try tonight
Message 14 of 22
(2,818 Views)
i finally got back to figuring out this VI, and now I seem to be getting the error finding the file named "svl_Spectrum Type.ctl"...
another problem, (might be related)
SubVI 'Octave PSD Conversion(N-ch).vi': subVI is not executable
The subVI is not executable. You must fix all errors in the subVI before this VI can run.
Message Edited by Anatoly2 on 05-12-2005 03:22 PM
Message 15 of 22
(2,787 Views)
The "svl_Spectrum Type.ctl" should be installed in this directory:
C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\addons\NISVL\_NISVL.llb
Try browsing there to find this control. You might also consider performing a mass compile on some of your VIs if they are having trouble finding their subVIs. Check out the LV help file for more info on mass compiling.
-Jack
Message 16 of 22
(2,757 Views)
-Jack
i did a search, and i don't have the file svl_Spectrum Type.ctl on my hard drive... is it in a zip somewhere?
Message 17 of 22
(2,752 Views)
Since it is in an .llb, the windows explorer won't find it. You should be able to browse to the .llb, double click on it and see the files that are inside.
-Jack
Message 18 of 22
(2,747 Views)
svl_Spectrum Type.ctl is not in the _NISVL.llb file
Message 19 of 22
(2,745 Views)
Hmmm...strange. Did that VI used to be there? You might want to try and perform either a Repair on your installation or uninstall and reinstall the Sound and Vibration Toolkit.
-Jack
Message 20 of 22
(2,730 Views)
