Making pictures popup
Smiley Wink How can I pop up pictures with every step of the program while when some conditions  are broken(!true) a certain different picture will come up.
The idea is every step is appointed with a different picture.
Thanks In AdvancedSmiley Wink
Message 1 of 11
(6,883 Views)
Can you elaborate your point further, i am little confused what exactly you want?
If you want to display some image on event it can be done easily.
just search on the forum for it.
Regards
shrek
Message 2 of 11
(6,880 Views)
Robot HappyWell,I have a project that I am almost through with it and I want to add to it(additional application) for every play that is played to display a picture that is unique and when one player wins a special picture different than the previous is revealed (two different pictures) .I want to know how can I "call these pictures one at a time to be displayed on the runtime of the game and when one of the player wins(breaking of the conditions),another picture(example trophy ,cup)
to be revealed.Thank you for your time and patience.
Thank you in advance.:womanhappy:
Message 3 of 11
(6,862 Views)
you can use a picture ring control and its visible property, so that if a condition is met for the picture ring control to show it will.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 4 of 11
(6,855 Views)
Thank you Harold,I got the point behind what you said and I have just tried it and it worked perfectlySmiley Happy
How can I change the color of the front panel using the property node.
Thank you very much.
Message 5 of 11
(6,828 Views)
You can try this to change the front panel color with a property node.
Ben
Message 6 of 11
(6,800 Views)
Hello,I have a difficulty in producing this C icon(appeared three times)[where can I find it and what does it mean]And how can I make the property node for the VI and Pnl
ThanksSmiley Tongue
Message 7 of 11
(6,777 Views)
those are close reference.v, and to make the property node for the vi you can use the open VI reference.vi
Message Edited by Harold Timmis on 12-12-2009 07:56 AM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 11
(6,770 Views)
or you can do this:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 9 of 11
(6,763 Views)
I done the simulation you posted but a black color is always appearing(why is that?)
How can I change the color?
Thank you.Smiley Tongue
Message 10 of 11
(6,746 Views)
