Making the numeric indicators link with the temperature graph
I've got numeric indicators in my block diagram. The numeric indicators show the temperature and the graph is supposed to show the numbers running. Like for example when I put Annealing-90 degrees, Denature-60 degrees and Extension-55 degrees, the graph is supposed to plot those temperatures in order of Annealing, Denature & Extension. Anyone can help out here on what I can use to make this work?
Message 1 of 17
(5,895 Views)
I caanot look at yor code because I am posting via phone... Maybe you could simply replace your indicator with a chart, then also show the numeric indicator if the chart. See how far you get.
Message 2 of 17
(5,894 Views)
What is it that you want to do?  What is your VI actually doing and how is it different from what you want?
Message 3 of 17
(5,882 Views)
see screenshot
Message 4 of 17
(5,858 Views)
I've tried the screen shot that you gave but I see it only running 3 lines though. How do I make them run as a temperature graph? As in there should be a fall and rise in each temperature change. Thank you for the screen shot.    Smiley Happy
Message 5 of 17
(5,829 Views)
I would suggest adding some sort of timing into your while loop also, otherwise it will eat up a lot of processor time!
Kind Regards,
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
Message 6 of 17
(5,816 Views)
I've included the timer to let it run normally, but I can't get it to run as a smooth graph with the temperatures. Should I include array in this ? The image is how the graph should be runnig.
Message 7 of 17
(5,800 Views)
Your question makes no sense. You have three separate temperatures that you manually set and these are being displayed accurately on all your charts. You've discarded the data that used to be automatically generated. If you wanted that displayed, you should not have deleted it.
Message 8 of 17
(5,777 Views)
I've included back the array into the for loop but I'm not sure how or where to connect the numberic indicators to the for loop. Any help?
Message 9 of 17
(5,733 Views)
Hi Karnan,
To start off I wouldn't connect your 'Extension 2' control to the N terminal on your for loop. At the moment it will run the loop for the amount of time specified in your Extension control on your front panel.
John McLaughlin
Message 10 of 17
(5,723 Views)
