Making the "G# Dependency injection using default constructor" example work in built app.
I'm trying to make the G# example called "G# Dependency injection using default constructor" work after the build. The example works fine in debug mode, but after having made a built specification and built the app, it doesn't work and gives me this kind of error:
Infos sur le fichier/répertoire dans G#Object.lvclass:G#Object_GetClassType.vi->G#Object.lvclass:G#Object_GenericDefaultConstructor.vi:1->G# - DependencyInjectionUsingDefaultConstructor.vi<APPEND>
C:\temp\testDILV\Application.exe\1abvi3w\examples\AddQ\G#\CreateDestroy\MyG#SubClass_class\MyG#SubClass.lvclass
So it seems that he cannot find the path, but the path is given by the G#Object_GetClassPath vi, so it should be correct. It returns the path in the form C:\temp\testDILV\Application.exe\1abvi3w\examples\AddQ\G#\CreateDestroy\MyG#SubClass_class\MyG#SubClass.lvclass but G#Object_GenericDefaultConstructor doesn't seem to find it and crashes.
Is there something I'm doing wrong? Maybe in the build specification?
(2,875 Views)
Community thread
Qestit Systems
Certified-LabVIEW-Developer
(2,840 Views)
