Malleable VI Adapting to LV Class
I want a malleable VI whose input can adapt to either an array of U32, or a class whose private data contains an array of U32.
The VIM can't be outside the class, because then the only way to access the class's data would be a property node, which isn't allowed in a VIM.
If I make the VIM a member of the class, it doesn't work because a class unbundler isn't allowed in a VIM.
Is there any way around this?
(1,424 Views)
I don’t know about classes, but in the past with references when I wanted to use a VIM  I put the property node in a SubVI and put the subVI in the VIM. That worked.
mcduff
(1,394 Views)
@paul_cardinale wrote:
..the only way to access the class's data would be a property node..
Why not just call the accessor VI as a subVI instead of with a property node?
I haven't tried, but presumably it should work.
___________________
Try to take over the world!
(1,360 Views)
That’s what I ended up doing.  Works fine.
(1,344 Views)
