Managing Telnet via Labview
My aim is:
open a Telnet session on a radio equipment,
Perform some command lines about registers content in a while do loop.
close Telnet session.
Is it possible using the Prompt block diagram?
Is there any downloadable tool to make it easier?
I hope in your help
Bye to all
(2,765 Views)
The NI Internet Toolkit has Telnet VIs which you can use for your task. See the following for details:
http://sine.ni.com/apps/we/nioc.vp?cid=2501〈=US
You may want to check, from the box on the right-hand side, the reference manual under Product Manuals. This gives you specific details on these VIs.
Hope this helps.
Khalid
(2,765 Views)
