Mandatory terminal input
When creating sub vis can I create an input that if not
wired would create an error ?
(3,394 Views)
Accepted by topic author Ben_01880
Yes!
When you wire the connector pane select the terminal right-click and chose "this connection is-  required"
(3,393 Views)
Thank you
(3,381 Views)
Also, note that there is an options setting on the Front Panel Tab to make "Connector pane terminals default to Required".
Omar
(3,368 Views)
