Mangled function name in Call library function node
I am modifying an existing LabView wrapper project, I added one function, and even though I used the same export settings as it is used for all other function, only the new function name appears mangled.
The DLL code:
#ifdef OS_WINDOWS
# define EXPORTSPEC extern "C" __declspec ( dllexport )
#else
EXPORTSPEC int S7API lv_Srv_RegEvents(S7Object Server, LVUserEventRef *EventRef, PSrvEvent EventData);
 The Call library dialog:
Even if the function itself is empty, LabView still fires the general memory corruption error.
Please help.
(3,739 Views)
Duplicate post
(3,734 Views)
I notified to moderator to delete one.
(3,730 Views)
Accepted by topic author Bublina
Oh me,
the S7API definition ment __stdcall
Smiley Frustrated
now it works nicely...
(3,724 Views)
