Manipulation array
Ok well,
I`m currently block on one simple problem, But I don`t find the solution......... And sure it is simple....
It`s easier with one drawing, I want to do this :
1 1
2 2
3 3
4 4
5 5
6 6
And want to change the array to have :
1 1 4 4
2 2 5 5
3 3 6 6
I found this post
http://forums.ni.com/t5/LabVIEW/array-manipulation/m-p/2871852/highlight/true#M835498
I don`t have lbview 2012 but one older version, I tried to play with shifts register and build array, but I`m a little lost.
If someone has the solution, it`s welcoming.
(3,997 Views)
Accepted by topic author Gerday.M
Hi Gerday,
sure it's simple:
(3,984 Views)
You can use Insert Into Array in order to combine 2D arrays "next to each other" instead of "on top of each other", allowing you to simply split the array and then recombine:
(3,953 Views)
Thanks it is very good for me.
Thanks ^^
(3,949 Views)
