Manipule Color of plot
Hello, I am working with a graph and I am looking for the way that by means of a button allows me to change the color of the signal, that is to say to control the color. Regards
Message 1 of 10
(4,463 Views)
Hi Jp,
use a color property of the plot.
(Don't forget to set the ActivePlot before changing properties for a specific plot!)
Message 2 of 10
(4,421 Views)
You can click the plot in the plot legend and change the color. If you need it programmatically the answer is above.
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 10
(4,415 Views)
Hi, ineed to do it by means of a button, to manipulate it at will
Message 4 of 10
(4,396 Views)
That is what this is for:
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 5 of 10
(4,385 Views)
I need to control the color with a button
Message 6 of 10
(4,382 Views)
That is a button...
Redhawk
Message 7 of 10
(4,368 Views)
I need to do with a boolean or push button, no with that
Message 8 of 10
(4,364 Views)
Then the answer that GerdW gave you is what you need. Do you have a more specific question? Have you tried implementing this and ran into problems? Please feel free to post some code for help.
Message 9 of 10
(4,351 Views)
Accepted by topic author Jp16
Plot Color.pngHere's a little example.  Note that the Active Plot parameter (ActPlot) is above the Plot.Color parameter.  The property nodes are read top to bottom so set the active plot, then change it's parameter.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 10 of 10
(4,327 Views)
