Manufacturer suplied drivers on IDNet shoud require documentation and examples
Why aren't manufacturer supplied LabVIEW drivers required to be documented and have working examples?
Nothing makes my job harder than having to plod through undocumented VI's to figure out how to make them work.
The last set of drivers from Keysight I got off the IDNet literally said
Use the Example Finder to find examples demonstrating the usage of this instrument driver.
To launch Example Finder, select "Find Examples..." from the LabVIEW Help menu.
But that comes up empty and there are NO examples in the drivers package I downloaded.
=== Engineer Ambiguously ===
(1,331 Views)
That's interesting, Keysight is usually pretty good. Do you have a link to the drivers you downloaded?
(1,326 Views)
