Many Queued SM in one Timed loop Vs Many Timed loops
LV 2009 + Win7 + PCI 6229 card.
There is a need to control 4 different equipments from a single code. The equipments are identical but have two modes of operation which can happen at random.
Each equipment has its own Queued State machine ( QSM) which is inside of a 10ms Timed Loop. So which of the following options is best ( efficient )  to handle this ?
A. 4 different QSMs all running inside of a single 10ms timed loop.
B. 4 independent  10ms timed loops each handling one QSM. The timed loops have different priority assigned to keep things in order.
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(2,728 Views)
Accepted by topic author MogaRaghu
And undoubtedly the right answer is option (A). I tried to simulate both options on a P4 machine with 3 GB ram and the option (B) was struggling to run particularly when starting up. And randomly stopping for a few seconds in between consuming 100% of processor time.
So I go with Option (A).
Raghunathan
(2,699 Views)
