Map Allen Bradley 1400 addresses to NI Modbus addresses
How do I map Allen Bradley 1400 Micrologix addresses like (N7:0, B3:0/1, etc., etc.) to NIs modbus addresses? Can the NI DSC module access the PLC for read/write operations without using the NI OPC server?
Is there any tutorial or URL  which specifically addresses the above queries?
Thanks in advance.
(4,296 Views)
If the PLC supports Modbus communication, you can do one of two things:
1. Either use the free NI Modbus Library for LabVIEW.
2. Use the LabVIEW DSC Module. Help for that is provided under here. There are a couple of links there to help you get started with Modbus using LabVIEW DSC.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,289 Views)
It's easier if you are using OPC ... you can map and bridge data between the two protocols quickly through tags (addresses).
Here is what you need:
Modbus << OPC Data Manager >> Allen Bradley
Data Manager allows one-to-one, one-to-many, and many to many relationships between tags
Let me know if you have any questions.
Wassim Daoud
Senior OPC Architect
(4,260 Views)
Thanks Wassim and Adnan. The PLC does support Modbus protocol. However, I am told that the PLC code writer should have used Modbus addresses rather than ABs standard format like N7:0, N10:1, B3:0/1  etc. Is there a way out? Sorry if I am being naive in my questions.
Thanks in advance,
Paul
(4,251 Views)
