Map Input Size
Hi, I am wondering how I can reduce the Map input shown below. I can successfully increase the size of it but I cannot find the way of reducing its size (number of Rows and Columns) . Thanks in advance.
(4,588 Views)
Hi Roberto,
Reduce in which way?
To show less elements on the frontpanel you can grab the array border and make the array indicator smaller. This only reduces the visible area of the array…
(4,580 Views)
Accepted by topic author Robertocima
if i assume correctly you have a 2D-array-control, use a property node and set "NumCols" and "NumRows", that changes the displayed 2d-array
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(4,576 Views)
hi, yes I tried that way but I want to reduce the actual area of the array. For example if the original array is 50x50 I would like it to be 40x40. If I do what you just said I will be able to see a smaller array but it is still 50x50.
(4,573 Views)
see the last frame of my snippet, the function's name is "Reshape Array"
(4,570 Views)
I would use ArraySubset to get a subset of the current array data…
(4,550 Views)
gerdw is right, if you want to have like the "middle portion", the "reshape array" will not give you that
(4,547 Views)
