Marker allignment in XY Graph
I am Using Labview 8.6. I am plotting XY Graph In which Y Axis = Time and X Axis = Value.
When I am Plotting data for 24 Hour means my main Division = 12 = 120 min / Div and Sub Division = 12 = 10min/Div.
But When I am plotting the graph i missout the sub division from the ist main division. (please see the attached file)
So please help me to sort the problem.
Prabhakant Patil
Regards
Prabhakant Patil
(3,413 Views)
This is not clear to me Smiley Sad
Do you bother about the missing sub divisions in the lowest main division (19:00:35: 06/07/2009) or do you want to remove all sub divisions while plotting?
That last can be done be setting the minor division to transparent "T" in the colour pallet.
Don't know if this helped but I tried Smiley Happy
(3,409 Views)
i Dont Want to remove Sub Division. actually this is main part of the Code.
Regards
Prabhakant Patil
(3,393 Views)
Please Check the attached Setting File For The Graph plotting
Regards
Prabhakant Patil
(3,389 Views)
Please Check the Attached Graph Setting File
Regards
Prabhakant Patil
(3,388 Views)
